CAN I????
Old May 23, 2003 | 08:46 AM
99MONGOOSE's Avatar
Default CAN I????
I have an ARE stage 2 H/C and put down 414RWHP through my 12 bolt with 4.10s and AFS chrome ZR1 17x11 w/ 315 steamrollers. I would like to run a 75-100 NX shot WET MAF kit. I am running NGK-TR55 plugs. Just curious if I could get by running the small shot 75-100 without having to de-tune my car while running N/A. I don't want to remove timing and swap to the TR6 plugs gapped at .035 when I will be spraying at most 20% of the time. I don't want to go through the hassle of fabbing the fuel pump. When the Racetronix plug'n'play unit comes out I will get it. I would like to just add the nitrous MAF kit and call it a day. Basically I just want to run a few 10 sec passes and have it in case I need it. I don't have a cage so I will only get a pass or two then I will get booted, but it will be fun. I currently have the SLP 85mm MAF but I would switch it out for the NX no problem.
Old May 23, 2003 | 09:06 AM
cameroz282k's Avatar
Default Re: CAN I????
i think you will be good to got with a nx or tnt kit 75 possibly 100 but that is only if your timing is not pegged out
Old May 23, 2003 | 09:27 AM
383LQ4SS's Avatar
If your on the rged edge on motor you will probably get some detonation. If your only going to spary a few times just put a few gallons of 100 oct unleaded in there and youll probably be ok with a 75 shot maybe 100. I wouldnt go any higher though
Old May 23, 2003 | 10:50 AM
T/A Medic's Avatar
you need to run the TR6s and you shouldnt have to decrease the timing... gap them at .040 an go for it
watch for KR though with atap when u spray
