Tach signal / nitrous line
Old Aug 13, 2007 | 12:44 PM
suburbanlife866's Avatar
Default Tach signal / nitrous line
I'm going to be installing my Nitrous Dave's dry kit next week. I just have a couple of questions.
1) What is the easiest place for me to access the wire for tach signal. I need to hook it up to my window switch
2) Also, what is the best way to run my nitrous line into the engine bay from the bottle (mounted on the trans tunnel)
Old Aug 13, 2007 | 01:13 PM
MrDude_1's Avatar
if you pull out the PCM, you'll see theres a grommet on the firewall down there.
you can run your nitrous line, and the wire for your window switch thru that area (use different holes though)
i always tap into the tach signal wire either near the PCM if running it into the car, or at the connector on the wheelwell (i forget if its C100, C101, ect)
Old Aug 13, 2007 | 03:26 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
Tach signal...pass side of the engine
Old Aug 13, 2007 | 03:49 PM
Black2001z06's Avatar
How about a Throttle Position Signal wire location?
Do I need to tap into the TPS connector(if so, what color) or can it be read off the PCM?
Old Aug 13, 2007 | 03:53 PM
MrDude_1's Avatar
since the wire goes from the throttlebody to the PCM, you can tap it off near the PCM.. makes for a cleaner install.
Old Aug 13, 2007 | 05:11 PM
hey thanks a lot for the help guys. Like I said my buddy and I are going to attempt the nitrous install outselves. Hopefully everything goes well!
Old Aug 13, 2007 | 10:48 PM
Sounds sensible.
Therefore, I'll just tap both the tach and TPS off at the PCM.
Got a pin #, pic, or color at the PCM for the TPS wire?
My car is at the shop, therefore I can't verify...
Old Aug 14, 2007 | 06:34 AM
HAHA MrDude that thread is great!
Old Aug 14, 2007 | 06:49 AM
rdmelton's Avatar
Here's my nitrous install page that answers both questions: http://www.rdmelton.autoeducation.co...6/nitrous.html
The short answers:
1: For my 2000 WS6, the TPS signal is pin #24 (dark blue) on the red connector and the tach signal is pin #10 (white) on the red connector. Wiring connectors for other applications may vary so be sure to check the factory diagram before splicing wires.
2: I routed the nitrous line from the bottle, through the center console, through the floorboard near the shifter, beside the transmission, and then up to the solenoids. I used several zipties to ensure that it stays as far as possible from moving objects and/or items that will be hot.
Old Aug 14, 2007 | 06:27 PM
BayAreaSS's Avatar
I tapped into the #10 pin on the red connector on the PCM. I ran my nitrous line behind the pcm through the grommet and under the carpet along the passenger seat all the way to the trunk.
By Brett Foote | 2026-06-04 05:00:17
