Considering the juice..
Old Aug 16, 2007 | 05:37 PM
Tram's Avatar
Default Considering the juice..
OK guys-
I am thinking about putting a 75 shot through my car.. I'm just thinking about it at this point and have not made up my mind..
A few questions:
1. Would a 5 pound bottle be enough for a few shots? I don't run it on the track, only for screwing around on the streets..
2. How long will the juice last in the bottle? Can I fill up in June and keep the same stuff until August or what?
I'm a pretyy big newb to the nitrous scene..
Thanks
Jeff
Old Aug 16, 2007 | 06:15 PM
Empatho's Avatar
why dont you just get a 10lb bottle? Im getting a dry nitrous kit + purge soon and Im going to spray 75 and move up from there. with a 5lb I dont think its going to last that long
Old Aug 16, 2007 | 06:18 PM
sworaz's Avatar
Go with the 10 pounder and then you don't have to fill up so frequently. As long as you don't go with too big of a shot you will really enjoy the boost safely without having to upgrade fuel pump and injectors, you will even surprise a few cars you normally wouldn't.
Old Aug 16, 2007 | 06:27 PM
Tram's Avatar
Well, I figured I could hide the bottle easier on a 5lb and I really don't think I'll use it that often..
I will not put a bottle on the hump or in the t-top well.. I'd also like to keep the spare...
I've thought about putting it in the floor behind the drivers seat, but I dunno about that..
Old Aug 16, 2007 | 06:59 PM
02NBMWS6's Avatar
Originally Posted by sworaz
As long as you don't go with too big of a shot you will really enjoy the boost and even surprise a few cars you normally wouldn't.
so the smaller the shot the more you enjoy it and the more cars you surprise?
its the other way around for me
Old Aug 16, 2007 | 07:20 PM
Tram's Avatar
Well, my car will already be a h/c car.. So, I'll probably surprise a few cars here and there..
I was just thinkin' about a lil' somethin' extra..
Old Aug 16, 2007 | 07:34 PM
transamfreak01's Avatar
with a 75 shot you arent going to feel much. i say put 150 shot w/ a 10lb and spray away
Old Aug 16, 2007 | 07:35 PM
oh and if u want to hide the kit try a search for the money maker kit
Old Aug 16, 2007 | 07:53 PM
Tally TransAm's Avatar
i was in the same boat as you. h/c full bolt on for a long time and got an itch to go faster
after lots of thinking i upgraded my fuel pump and went with a single nozzle wet kit so i wouldnt have to upgrade injectors and i couldnt be happier.
noticable difference with the 75 shot
Old Aug 16, 2007 | 10:25 PM
Empatho's Avatar
you should be able to notice the 75 shot most are rated at the wheels now days
Old Aug 16, 2007 | 10:35 PM
donkey mule's Avatar
I have a 75 wet shot that I occasionally run ( I usually have the 150 jets in ). The kit I have is rated at the crank. The 150 is awesome! I will forewarn you that when you start spraying it is addictive and like any junkie you will eventually up the dose!
Old Aug 16, 2007 | 10:43 PM
Empatho's Avatar
+2
when I first got my car I was like "this thing is fast I dont need anymore" and know it feels slow because I got used to it so I want more
Old Aug 16, 2007 | 11:41 PM
sworaz's Avatar
No, I mean that if you have a bigger shot you have to consider fuel pump/injector upgrades....
Old Aug 17, 2007 | 12:34 AM
02NBMWS6's Avatar
if my post was valid enough to cause you to edit your post, why tell me to GTFO
Old Aug 17, 2007 | 01:05 AM
CaMaRo67RS355's Avatar
10lb bottle with at least a 100 shot
Old Aug 17, 2007 | 02:06 AM
02NBMWS6's Avatar
x2
Old Aug 17, 2007 | 03:01 AM
99Silverado5.3's Avatar
Do it and don't think twice. Simply the most hp/$ hands down.
Old Aug 17, 2007 | 09:58 AM
sworaz's Avatar
Jeesh, calm down don't you have anything better to do than start arguments based on unlogical assumptions...hmmm 75 shot feels better than 125 shot-are you seriouis that doesn't even make sense, just drop it already.
Btw I edited my post so that I don't have to sit online in petty arguments with idiots all day
Old Aug 17, 2007 | 11:37 AM
SPLATT's Avatar
back on topic. I say do it. But you better throw away the 100, 125, and 150 jets when you get it haha.
