Stock Clutch? Will it last on the juice?
Old May 24, 2003 | 06:14 PM
LS1FenixBird99's Avatar
Default Stock Clutch? Will it last on the juice?
I have a 99 M6 Trans, and i was thinking about doing a 100-125 wet shot. The car has 43k on it, and a stock clutch as far as i know. (bought used) Would my clutch last?
Old May 25, 2003 | 01:00 AM
cameroz282k's Avatar
Default Re: Stock Clutch? Will it last on the juice?
no mine was giving me hell on just a 75 shot so i went to the ram set up that clutch is awsome
Old May 25, 2003 | 10:28 AM
Z06PSI's Avatar
Nope...
Old May 25, 2003 | 01:09 PM
Benjamin Russick's Avatar
No way...
Old May 25, 2003 | 02:20 PM
FastBlackTA's Avatar
nope
Old May 26, 2003 | 03:47 PM
mike c.'s Avatar
my stock clutch blew with just some boltons and no drag tires.the stock clutch sucks.
Old Jun 5, 2003 | 09:14 AM
R01ws6's Avatar
I am running a 100hp dry shot. I have had my NOS setup for 2 summers now. and no signs of stock clutch not holding up. I think it depends on the drivers. If ya wanna go out and do whole shots with the stock clutch on a daily basis, it is not going to hold up. I use my NOS after 2nd gear. and my clutch is not even close to giving out. Point is.. Depending on the driver or drivers, your clutch can last for a long time or No time
Old Jun 5, 2003 | 06:39 PM
Assassin's Avatar
My stock clutches would blow up when I hit 2nd gear on the juice, if you launch 1st then hit 2nd, THEN turn on the juice you'll be fine, but dont even think of useing it before that, it will
