window switch not working right
Old Aug 17, 2007 | 07:29 PM
flash12t's Avatar
Default window switch not working right
HELP !!!!
okay i pmed dave but i remember him saying he was ganna get married so i dont think hes ganan respond to my pm for a while .. .
heres the problem. . i had my kit installed for bout a year now .. and i took it off bout 3 months ago but left the window switch wired up i hook the the kit agian and it only sprayed to 4 grand thought the window switch lost its memory or sumthing so tryed to reprogram it nothin doing it doesnt read the tac correct i know im getting a good signal because my shift light is piggy backing off the wire. . . . any input ??
Old Aug 18, 2007 | 05:30 PM
flash12t's Avatar
ttt need help guys!!
Old Aug 18, 2007 | 06:06 PM
Beer99C5's Avatar
http://www.fjoracing.com/products/rp...umentation.pdf
either 00 for the tach setting at the coil pak, or I think 4 if from the PCM
You can check and see if the RPM's is correct by holding the first button down after it is programmed.
The above pic shows idle at 700 RPM.
Old Aug 19, 2007 | 04:46 AM
flash12t's Avatar
i know thats how i know its not reading the tac correct 00 at idle it reads 32 and 02 is reads 01 ive tryed them all it doest read it correct. . could i have fired sumthing ?
Old Aug 19, 2007 | 04:57 AM
Beer99C5's Avatar
Step 1 from the instructions
Try 04 for the setting if your pulling the signal from the PCM
If that dont work call Dave, Ray or Chris at Nitrous Outlet Monday.
