WOT activation
Old Aug 21, 2007 | 11:50 PM
eLTwerker's Avatar
Default WOT activation
Just a general question about nitrous systems activated at WOT. If I hit WOT then back off, how long will it spray? Will it only spray while I have the pedal on the floor? I'm kinda foggy on the whole concept I guess.
Old Aug 22, 2007 | 09:22 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
WOT = Spraying
Not WOT = Not Spraying
now I am sure there is a fraction of a second for the line to empty after the solenoid closes but it is so negligible I wouldn't worry about
Old Aug 22, 2007 | 01:09 PM
5_02ls1's Avatar
It doesnt work like the fast and the furious makes it look to.....it only works when your button is pushed or a window or wot switch is activated.....
Old Aug 22, 2007 | 01:28 PM
MrDude_1's Avatar
once armed and setup, the WOT switch is like an "on/off" switch for the system.
if you're floored, you're pushing the switch. its on.
if you're not quite floored, the switch is not pushed, and its off.
