Nitrous Safety from Dynotune at $99!!!!!!
Old Aug 27, 2007 | 02:04 PM
DynotuneN2O's Avatar
LS1TECH Sponsor
n2ocamaro: You can use both if you like at the same time.
defenestrate: You can use the stock O2 or a wideband. I prefer the wideband as it is there for tuningn and reads the actual A/F instead of just the O2 voltage.
No GP planned - we give you our best price from the start - we do not offer high prices only to put them on sale. There is not another product like it on the market made in the USA with the quality that Dynotune offers.
Dean
Old Aug 27, 2007 | 03:55 PM
Nitro Dave's Nitrous Outlet's Avatar
Dean,
Pretty cool looking product...
Dave
Old Aug 27, 2007 | 05:10 PM
kc533's Avatar
Cool product man
Old Aug 27, 2007 | 07:44 PM
camar0corey's Avatar
Damn, so much cool stuff keeps coming out. I'm gonna be half way to a supercharger at this rate.
So if I wanted a wideband I could get this and then get the 02 sensor required? This is very tempting, I could mount this in my glovebox, and forget about replacing my narrowband autometer gauge.
Old Aug 28, 2007 | 07:27 PM
So quick question, to display wideband numbers, do I just need a wideband o2 sensor for it then, or something else?? Sorry, don't know much about wideband stuff.
Old Aug 29, 2007 | 07:50 AM
LS1TECH Sponsor
You would need a wideband setup such as the LC1 or many of the others on the market to display wideband.
Dean
Old Aug 29, 2007 | 08:41 AM
Beer99C5's Avatar
Be pretty sweet in a 2 1/16" gauge housing, mounting and putting it in a panel/console would be easier
Old Aug 29, 2007 | 12:52 PM
Justa Z's Avatar
this sounds very nice, im gonna have to wait till this comes out insted of getting a fpss for the new kit
Old Aug 29, 2007 | 02:24 PM
socmguy's Avatar
Restricted User
I would also like to see this in a 2 1/16" setup. I'd buy one right now
Old Aug 29, 2007 | 06:36 PM
Can the wideband controller run two things? Just curious as on your site you have the LC-1 controller by itself for the same price as the LC-1 to convert the autometer narrow, which I have, so I was wondering if I got the autometer version if it would also work your switch?
Either case I'm looking at $300 and some change for what sounds like the best way to shut down if there is a issue, sounds not too bad to me.
Old Aug 29, 2007 | 07:18 PM
defenestrate's Avatar
im just about finished on my nitrous-would i be safe spraying for the first time using this?
Old Aug 29, 2007 | 08:25 PM
  #32
navyblueSS's Avatar
Cool looking product, nice price too. I will be ordering one when they come available.
Old Aug 29, 2007 | 10:39 PM
  #33
usd2sing's Avatar
ok, i have to ask.
is this just an updated version of the model sold 6mo ago? ($149)
with digital display now?
reason i am asking is because we never got the earlier version to function correctly.
at any setting,
both with nb and wb.
long phone calls following every test while on the phone and nada. never worked correctly.
is there something revised or improved in this new model beside a digi display?????????
Old Aug 30, 2007 | 06:59 AM
  #34
LS1TECH Sponsor
Originally Posted by usd2sing
ok, i have to ask.
at any setting,
Please read the original post were we describe the features - this unit and the old unit have absolutely nothing in common with the each other. The electronics are 100% different as well as the algorithms in the software. Read the features compared to the old - as I mentioned in a previous post you are comparing a Cavalier to a Ferrari. SOrry you did not get the old one working well we have many out there and customers were very happy. But as I mentioned night and day. Not even a compariosn. Some of the features:
Checkout all these features:
Microprocessor contolled
Built in Air/ fuel ratio display(narrow and wideband)
peak and Min A/F memory during the run
multiple outputs 12V and Ground
Multiple inputs 12V and ground
Programable trip point
Fast response
Super Low Current Draw
Micro Package Mounts AnywhereWe have been testing this unit quite extensively and you will be pleasently surprised!
How it works
The unit will start monitoring on a 12v trigger input or a ground input trigger. It will only start monitoring when nitrous is spraying.....The monitor start time has a delay so you can let your system settle down a bit say if you have a little lean spike for the first .3 seconds....we let you pick your own delay start time beore the lean switch will start monitorig the o2 sensor
Dean
Old Aug 30, 2007 | 07:01 AM
  #35
LS1TECH Sponsor
Yes it will work one output on the LC1 will run your autometer guage the other will run the A/F nitrous shutoff switch.
This product will be great for first time users or seasoned nitrous veterans. You can never be too safe!
A round version most likely will be in the works down the road.
Dean
Old Aug 30, 2007 | 05:06 PM
  #36
2002RamAir's Avatar
So how rich can you set the unit, for us really paranoid people with a wet kit that would like to purschase two units...One to shut down system at lean and one to shut down system if too rich to prevent all damage!!!!
Old Aug 31, 2007 | 02:31 PM
  #37
LS1TECH Sponsor
We did not add a too rich feature to this product. If your very rich you will see it on the guage and you will loose a lot of power. Typically no damage is done - lean is really what causes the problems!
Dean
Old Aug 31, 2007 | 04:27 PM
  #38
Jogar80's Avatar
So, this will read enough to shut down even if going lean in only one of the back cylinders? Or is this pretty much just in case a fuel solenoid fails?
Old Sep 4, 2007 | 07:19 AM
  #39
LS1TECH Sponsor
Does not matter what the cause - anything that causes your air/fuel to go leaner than your programmed setpoint the unit will shut your nitrous down.
Dean
Old Sep 11, 2007 | 04:58 PM
  #40
Anyone use one of these yet?
