Questions for people who run N20 and head/cam car
I was thinking about spraying about a 100 shot on top of my head and cam combo- i feel like it would be nessessary to redo my fuel system.
What kinda of luck have all of u had with a similar setup.
Appreciate the help
Appreciate the help
I am running a TNT 100 shot ontop of TEA 5.3 heads. My old hand ported LS6 heads made 550rwhp and 605rwtq netted me 128mph traps. After switching cams and going to the TEA CNC heads the car hits 134 in the traps. I have yet to see problems with fuel pressure but I think that your on the edge if your car makes in the neighborhood of 550rwhp.
Phillip
Phillip
phil that is some very impressive trap speeds, those could be good for high 9's.
SO u say u do not have anything done to ur fuel system, and could you give me the part number for that kit.
How do u spray it, what kind of safty pills do u have, all info is very helpful thank you.
I used to run a TNT 100 Wet Shot on top of MTI Heads/Cam Combination. Stock 28 lb injectors with a Vortech Inline Fuel Pump. HP was over 550, torque right at 600 ft lbs.
This was a great set up; didn't have a single problem with it in a year of daily driving.
Good luck with your project.
Stock fuel pump, stock injectors, fuel lines and rails
TNT F1 kit jetted to 100 shot
Turn it on at 3k and off at 6800.
Phillip
Inline pump for me on stock injectors. I have a Stage II heads/rowdy cam set-up. I think it's running a little rich right now, tho...
