Very lowest but still safe RPM to spray on an A4?
I know of a friend that killed his motor to death from spraying off the line many times. I got a window switch and Im spraying at 3000 amd shuts off ar 6000. Pretty safe
I have the stock torque converter and the NOS 5177 dry kit. I set mine up as a 2 stage the first stage is a 35 shot spraying right off the line using the WOT switch to activate it. The second stage is a 50 shot that runs off a window switch. I tried a 50 shot on the first stage but could get it to hookup so i went down to the 35 shot. Ive cut a 1.845 60' thats not back considering im running 2.73 gears
Well I spray 150-175 off the line with a stock converter and no probs,never broke anything so far.I usually bring it up to 900-1000rpm and as soon as I go wot I grab the system.
I think what will answere your question is,as long as you are wide open throttle you shouldnt have any probs.Now you grab the system at 15-2000rpms your gonna be asking god for your heads back......lol
I was spraying a 150 out of the whole saturday. I do have a Vig 3600, and I was only leaving at about 1500 and hitting the kit while the converter is flashing to about 3600......... BUT it was spinning and running out of fuel and the 100 shot actually went better(and I didn't even get to spray it out of the whole to the tune of a 11.50).
Josh S.
Josh S.
