Used Nitrous System
Old Aug 23, 2007 | 12:28 PM
zz4camaro1980's Avatar
Default Used Nitrous System
Got an easy one for ya.
I recently bought a used nitrous system...
What is the easiest way to test that both fuel/nitrous solenoids are working before trying it on the car?
I dont want to bolt it on and find out the fuel solenoid isnt working!
Is there anything else I should be checking with a used system? (just looking for the basics)
Thanks.
Old Aug 23, 2007 | 12:41 PM
Black99TransAm's Avatar
with the ignition key on (motor not running) arm the system with the bottle closed. then go under the hood and push the lever for the wide open throttle switch. you should hear both sylenoids click
Old Aug 23, 2007 | 12:52 PM
Danger731's Avatar
or put 12 V across it
Old Aug 23, 2007 | 12:53 PM
67Ranger's Avatar
indeed... you can kindof feel them if you hold your hand on each.
Old Aug 23, 2007 | 01:13 PM
has anyone ever had any issues with them being clogged? (just something I read on the internet, but never heard of myself)
