Lt1 nitrous cam
Old Aug 27, 2007 | 03:40 PM
derekderek's Avatar
Default Lt1 nitrous cam
Just wondering what a good drag racing cam would be for a LT1, It has LT headers full exhaust ,intake, and other goodies. I will be running 150-175 shot wet . Would I wan't a cam with a high LSA or low LSA ? Any suggestions would be great. Thanks
Derek
Old Aug 27, 2007 | 04:31 PM
Tony Shepherd's Avatar
Are you wanting a shelf cam or custom grind?
Old Aug 27, 2007 | 04:39 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
who are you and what do you know about nitrous or LT1's
j/k....
as stated by Mr. Shepherd, we need a little more info to be able to help.
Is it going to be cam only, and what is the car going to be used for?
Rpm range you want to run....tranny, gear, etc
Old Aug 27, 2007 | 06:43 PM
jmill96Z's Avatar
People will argue with me all day, but I think the Hotcam is a great nitrous cam if you're on a budget and don't want to get all out crazy. Of course a custom grind is preferred in most any application, but it's hard to argue with a stock internal with a few bolt ons and a hotcam +150 going 11.2 @121.
Old Aug 27, 2007 | 07:06 PM
derekderek's Avatar
j/k....
I am going witht the LE stage 2 kit So It Will be a custom grind. I just want an Idea of what I am looking for in a cam. It will be for track duty mainly. M6 tranny Spec 3 clutch , with 4.56's in the rear end. It might see some street time but not much. Thanks
Old Aug 28, 2007 | 10:00 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
If you are looking to spray under 200hp on a daily driver..I would have the cam cut for good NA performance you may give up a little HP on spray but not enough to lose sleep over. When you talk to Lloyd and Brett tell them you plan on running spray, Brett can then adjust the LSA/exhaust duration on the cam if needed.
Off topic a little but the 4.56's might be a little much for H/C and spray...but it depends on tire size....
Old Aug 28, 2007 | 12:07 PM
Ray.........I know nothing about LT1's
