Times and jet questions
Car went 11.0-11.1 on the motor spinning but still under a 2.0 60. On the first stage out of second it went 10.4@136 (high 9 mph) spinning. This is with a cowl hood but with a regular air filter top, belt driven water pump and a fan on it, M&H race masters. Before it goes out again it will have a K&N exstream filter top, EWP, and now has MT ET streets. Also have some double ADJ ontrol arms going in, LCA brackets and QA1 rear shocks. Heads and intake are not even ported hahaha, nor has it been dyno tuned....... hopefully will have it tuned before it goes out again also. It sould hook a lot better on these tires and the extra suspension parts and dip into the 10's N/A.
On jetting for Carb cars. What do you base the jet size off of per hp shot?
As in how do I know what jets to put in for the desired HP? This id for a carbed BBC car so pretty much nothing is stock.
Does solenoid size affect it?
