Couple of 'Help' questions.
1. Is the transducer the same thing the instructions are referring to as a bottle heater pressure switch? It looks like the server the same function are are just referred to by differnet names.
2. When wiring the switch panel, the instructions call for a 1k resisitor so the LED won't bunt out on the bottle heater switch. Is this resistor supposed to be soldered between the hot lead connector and ground lead connector on the underside of the switch ... so as to connect the hot and ground leads of the switch together with the resisitor?
2. NO. the resister goes inline of the power only. Ground just goes to ground.
go from your 12v source to the resistor, and from the other side of the resistor to the switch.
Robert
