Carb plate on efi victor jr fueling question
running victor efi with an elbow, have a dedicated fuel system from nitro dave, and a NOS big shot kit,
question is does the pressure on the dedicated system need to be for 6psi or 55psi and at what bottle pressure
Closed ex-Sponsor Account
Originally Posted by greatwhitess
I run mine on 7psi. Nice thing is you can tune the psi to get the afr you want.
Ditto.. I started off at 6psi and picked up 2 tenths going to 7psi.. I think it could have used a little more, but every setup is different. Be sure you have the correct jetting in the plate for a low fuel pressure setup..
you run the correct pressure for the jets, or rather vice versa We run 50-60 psi in the plate feed systems, you can run anything in between, with the right jets. Depends on if the nozzle were made to atomize correctly at a given fuel pressure realy more than anything else
