How much to spray on 04 Z06
Old Sep 14, 2007 | 05:08 AM
Chrisrokc's Avatar
Default How much to spray on 04 Z06
I have a 2004 Z06. Before I had a Trans Am that had a directport setup. So I know my way around nitrous pretty good. I am looking to go with the nitrous outlet plate kit. Looks like a good deal. What will the stock fuel pump support hp wise on a 2004 Z06? Do I need to upgrade before I spray anything? I am only thinking about spray a 100 for now. Maybe 150 or 200 2 stage down the road.
Old Sep 14, 2007 | 08:30 AM
TXZ0603's Avatar
250 2 stage
Old Sep 14, 2007 | 08:53 AM
1nicec5's Avatar
the stock fuel pump will handle 100 with out a problem. if you want to do 150 or more get a new fuel pump.
Old Sep 14, 2007 | 10:11 AM
Chrisrokc's Avatar
Any suggestions on fuel pump? I ran a racetronix kit in my trans am. I remember checking them awhile back and I got discouraged because they didn't have an upgrade for the 2004 Z06.
Old Sep 14, 2007 | 10:27 AM
Nitro Dave's Nitrous Outlet's Avatar
The racetronix would be the way to go on the fuel pump upgrade. Your stock fuel pump will support around 450-500.
A stock bottom end will support up to a 150 shot safely.
I like your choice in the system.lol
Dave
Old Sep 14, 2007 | 04:41 PM
Chrisrokc's Avatar
Thanks Dave
I am looking on Racetronix's web site and it says it doesn't work on the 2003 corvettes. I assume it really mean 2003 and up.
http://www.racetronix.com/RX-C5-FPK-2.html
Is this the case?
Old Sep 15, 2007 | 12:11 AM
Robert56's Avatar
The ls6 can easily take a 200/250 shot with a spot on tune. Many, many run this size hit in dual stage. Quikest and fastest stock block ls6/Z06 is 10.51, but of course it's a dry shot. Actually all the top spots are held by dry hits, and the catagory this falls under is "Stock LongBlock M12/LS6 with any Power Adder". Good luck on your fast times quest, keep me updated, as I maintain the Z06 Fast List over at the vette forum (many catagories).
Robert
Old Sep 15, 2007 | 12:12 AM
Robert56's Avatar
Originally Posted by Chrisrokc
Thanks Dave
Is this the case?
Correct. A BAP will help, as will a hot wire set-up, and/or an inline pump. Racetronics is working on a fix?
Robert
