got question about nitrous
Old Sep 15, 2007 | 02:34 AM
LS_WANG's Avatar
Default need info about nitrous
i got 01 camaro ss ms4 cam kit svo injectors and long tubes headers full exhausts cutout 4:10 gears and damn near all rear suspension i push 416 rwd hp i was thinking about pushing a bottle but dont know which one is best dry or wet and do i need to change fuel pump i was thinking about a 100 shot
Old Sep 15, 2007 | 02:37 AM
MyTA99's Avatar
You are going to need a fuel pump for sure you are already close to the limit.
Old Sep 15, 2007 | 02:39 AM
MyTA99's Avatar
As for the kit it is really just personal preferance. If all you want is a 100 shot a dry would be real easy to hook up.
Old Sep 16, 2007 | 12:44 AM
LS_WANG's Avatar
yeah i was thinking about the tnt kit from Texas speed and a Racetronix F-Body Fuel pump and then get another tune i might just push a 75 shot just to be safe i also got a stock rear end with 4:10 gear im light weight scared to blow that **** i have a bad feeling about this rear end but how do people end up putting nitrous with out changing fuel pump and stuff
Old Sep 16, 2007 | 11:24 AM
DuronClocker's Avatar
What SVO injectors do you have? That's a limiting factor in whether you can go wet or dry as well.
If you've just got 30#'s, I wouldn't spray a dry shot on that setup unless you plan on bumping the injectors up to at least 42#'s. I'll probably be swapping to 60#'s just to have some head room for my small (100hp) dry shot first stage. You're making close to the same power as me N/A.
