HSW -vs- Nitrous Outlet
Old Sep 16, 2007 | 08:31 PM
MadMike329's Avatar
Default HSW -vs- Nitrous Outlet
Opinions on which of one of these guys makes a better bang for the buck dry kit. They both have dual nozzle kits for about $350 or so. I was also thinking of the HSW single nozzle kit for $270. i'm not planning on running above a 150 shot and maybe not even that if i'm happy with a 125 shot. Also is there any benefit to running two nozzles vs running a single nozzle? Also planning on running a window switch so i'm open to suggestions on that to. Thanks guys!
Old Sep 16, 2007 | 09:02 PM
MadMike329's Avatar
Any suggestions, personal experience with either kit brand?
Old Sep 16, 2007 | 09:15 PM
GregWS6&z28's Avatar
go with your gut
Old Sep 16, 2007 | 09:26 PM
383LQ4SS's Avatar
Dude...its IMPOSSIBLE to make a bad choice on your two options you stated.
Just pick one of those sponsors and the best thing to do is give them a call. Or...keep reading here. Use the search feature since its working now. There are tons of satisfied customers using both setups.
Do a search on window switch as well. Any of the ones that either Nitrous Outlet of Harris carry work well. They wouldnt carry them if they didnt work.
You really cant go wrong bro. Pick one and pull the trigger!
Old Sep 16, 2007 | 09:28 PM
MadMike329's Avatar
right on guys, probably go with the single nozzle HSW setup then, i'm not planning on doing anything too crazy with N2O yet. Thanks
Old Sep 16, 2007 | 09:43 PM
porksoda's Avatar
I made this exact thread a couple weeks ago but it was about wet kits. What I got from it is that both are very reputable companies and you should call them to see who floats your boat.
+1 for NM!!!
Old Sep 16, 2007 | 09:48 PM
Matt@HSW's Avatar
If you won't go past a 150 shot you'll be fine with the single nozzle Sudden Impact kit. If you are going to spary more go with the Big Hit version with the larger orifice 3 port solenoid. Let me know if you have any questions.
Thanks,
Matt
Old Sep 16, 2007 | 11:41 PM
Robert56's Avatar
I do know that Matt and crew are premier dry tuners, and that goes a long way in getting your system set-up correctly.
Robert
