Losing a little antifreeze...
Old Sep 19, 2007 | 11:35 PM
waterbug1999's Avatar
Default Losing a little antifreeze...
Seems that N/A and WOT I do not loose any.. Spray my 100 shot and check it and some has been lost.
How bad is it? Is there a way to tell if its the heads lifting or a blown head gasket?
I wanna go to the 150 shot but after discovering this, I dont think it would be a wise idea. Any thoughts?
Old Sep 20, 2007 | 12:22 AM
jerrad's Avatar
Try a compression test. If you blew a HG I think it would show in the compression test.
Old Sep 20, 2007 | 01:21 AM
TwoFast4Lv's Avatar
Mine passed that test well. Then out of the blue it starts sucking water. Do not get me wrong I know when it happened and how.
How did that last pver a year?
Old Sep 20, 2007 | 01:56 AM
jerrad's Avatar
That sucks. I guess because it wasn't really broke more deformed it didn't effect it as much. When I blew my HG in the buick the middle cylinder blew where a inch gap and the back cylinder was just really streched.
Old Sep 20, 2007 | 02:02 AM
JMBLOWNWS6's Avatar
Cylinder pressure is probally high. You can always take some timing out and see if it resloves it. Otherwise some head studs and a gasket replacement will be needed.
Old Sep 20, 2007 | 12:01 PM
I changed the oil a month or so ago and I noticed it before that. The oil seemed/looked fine, just a little dirty. Will a blown head gasket leak antifreeze in the oil?
Old Sep 20, 2007 | 12:51 PM
jerrad's Avatar
it depends on where the gasket blows. when mine went it didnt. if it did the oil will look milky.
Old Sep 21, 2007 | 11:11 AM
Thanks... I guess I got a little project to do over the winter.
