ls1 carb to kuwait
Old Sep 20, 2007 | 07:43 PM
DASHTI's Avatar
Default ls1 carb to kuwait
my car trans 1998 drag
this is the specs of my car from kuwait
heads trick flow 64 cc 13.50 degree rocker t&d 1.8 valve 2.08 1.06 spring isky max lift 800
custom cam futral motor sports solid roller lift 731 714 duration 274 279 lop 112
piston je +10 dome pore 4.125 crank 4.000 calies rod 6.125 eagle
heads gaskets cooper block aluminum header kooks 1/78 2 intake victor jr carb 1150 cfm distributors and msd 7al digital 2 stage foger nitrous 300 shot and plat 150 shot and th 400 mike transmisiion 2.10 convertor ptc custom 3.500 rpm moser 12 bolt 35 splin 3.73 tire 29 10 15
PLEASE Give me your Recordation to the specs of my Cars
Appreciate guy's thanks
Attached Thumbnails ls1 carb to kuwait-formulla-carb.jpg   ls1 carb to kuwait-th400-2.10.jpg   ls1 carb to kuwait-alkoooooooooooooooor.jpg   ls1 carb to kuwait-20070903031-.jpg   ls1 carb to kuwait-20070909037-.jpg
Old Sep 21, 2007 | 08:00 AM
Noyzee's Avatar
8 second mod
looking good.
pretty sure i spoke with you a while back about this setup.
what is it running?
good luck for sure, looks killer
Old Sep 21, 2007 | 09:53 AM
ALLBOTTLE's Avatar
LS1TECH Sponsor
Only thing i would be scared of is that 12bolt, everything else looks good.
