low compression and spray
Old Sep 22, 2007 | 12:29 AM
z28boy's Avatar
Default low compression and spray
Hey guys was wondering if i can spay my car it has a stock ls1 bottom end and afr 225 heads with a 72cc chamber its being buit for a blower but cant afford it wright now, and i alredy have a wet kit. the cam is a 224/228 581 lift 114lobe. Any help would be great.
Old Sep 24, 2007 | 01:41 AM
uncle ray's Avatar
hell yeah spray it!!! if you dont then the nitrous fairy wont tickle you in your sleep and make you laugh while dreaming of killing poopstangs and imports!
no special difference between spraying on high of low compression, if anything you could probably run a larger kit do to the reduced possibility of detonation. put a 150-175 and dream of the days when your blower does it all the time!!!
Old Sep 24, 2007 | 11:13 PM
LSevil1's Avatar
Spray it with at least 150 and 200 max. I had pondered this for awhile
and due to finances at the time I considered doing a 300 shot (forged mtr.)
progressive on a MaxII NX/Direct port. Time went by and since then
a Nitro Dave plate has been added on the same low comp. motor that
is in my sig. Your cam will be fine, just do all the safety stuff and you'll
be fine. By the way, don't let my first post deceive you, I've Procharged
my TA to 600+ whp on a dif. set up back in 2003 and love LS series
motors with Forced induction. Let me know how it goes.
Later, Tim
Old Sep 26, 2007 | 11:16 PM
z28boy's Avatar
Thanks guys i will be putting the bottle on this weekend. As soon as i get some tr6plugs,JUICE And then i will see how this thing pulls off the transbreak.
