Think we fixed my issues ... FINALLY !!
Old Sep 26, 2007 | 09:25 AM
ATVracr's Avatar
Default Think we fixed my issues ... FINALLY !!
So it looks like the FJO(2 stage window version) could not handle the 4 noid set up.
We hard wired the kit to a switch and it worked perfect.
Then last night we wired in one of the newer FJO controllers with the noid drivers and it worked fine.
Looks like we should be able to finish up the Direct port tune and the DRY shot tune today then its off to the track Friday.
Old Sep 26, 2007 | 09:31 AM
Phil99vette's Avatar
7 Second Club
You going to crack 8s friday? MIR or Capitol? Good Luck!
Old Sep 26, 2007 | 09:51 AM
ATVracr's Avatar
Dont know if I have the power to go 8's at my weight(3720# last time I had it on the scales), I'm thinking 9.teens maybe a 9.doh
Capitol. Thanks... I may need it.
Old Sep 26, 2007 | 10:53 AM
LS1 SPEED's Avatar
Good Luck
Old Sep 26, 2007 | 11:14 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Good luck Wayne, you have a 10 pt in there?
Old Sep 26, 2007 | 11:47 AM
ATVracr's Avatar
Thanks guys!
I'm legit ... 10 pt, Lic. and a chute
Old Sep 26, 2007 | 12:24 PM
Noyzee's Avatar
8 second mod
nice, thats good.
thats why i always shoot for simple install, no fancy switches ect ect. glad you got it figured out. good luck for sure!!
Old Sep 26, 2007 | 01:06 PM
ATVracr's Avatar
Originally Posted by Noyzee
nice, thats good.
You dont run a N20 controller?
Old Sep 26, 2007 | 01:21 PM
Noyzee's Avatar
8 second mod
i run a nos delay box, but its not digital ect its simple as i could find and a wot switch.
Old Sep 26, 2007 | 01:25 PM
ATVracr's Avatar
The FJO was almost as simple it was just a window switch with a WOT switch built in.
Not real fancy.
The new one has a progressor built in but it can handle 40amps per stage.
Old Sep 26, 2007 | 01:42 PM
Noyzee's Avatar
8 second mod
Not real fancy.
yea, i run one in my vett. i did it because it was pretty simple and when my dad owned the vet i wanted somthing that was easy for him. but i had a few issues with them in the past. even in my vett, it runs off the tps, and i just didnt dig that. i also had an older nx controller and that went bad on me after a 6 hour drive to the track, so my raceing ended right after i almost tagged the wall.
it kicked on out of the hole like i wanted, then it **** out, im like hmm still in it. hit it more thinking i lifted hmm, then all of a sudden it worked broke the tires, car did a 80* turn toward the wall, so i just dont dig the dig stuff anymore. lol
Old Sep 26, 2007 | 08:07 PM
BLK02WS6's Avatar
Glad to hear you got it straight - Good Luck Friday!!
Old Sep 27, 2007 | 09:13 AM
ATVracr's Avatar
Thanks.
Got it tuned and took it home last night. We left it fat on both stages.
It really likes being leaned out, going from 10.2 to 11.2 AF picked up 60hp.
200 in the 1st stage and 150 in the 2nd. Sounds mean on both hits
Old Sep 27, 2007 | 12:26 PM
ShiznityZ28's Avatar
Thanks.
No joke! It should rle out. I think we will have hooking issues though since its capitol onfriday night. but It would be nice to see 150
Old Sep 27, 2007 | 01:05 PM
Noyzee's Avatar
8 second mod
you guys run on MT radials right?
what size?
Old Sep 27, 2007 | 01:33 PM
ATVracr's Avatar
Shiz is running the Hoosier Drag Radials.
I have the M/T's ...... both are 315/60/15's
The hoosier is a little more of a race tire (alittle lighter also) than the M/T's.
The pic of my car in my sig. is on Hoosier 325/50/15's Drag radials. They work !!
Old Sep 27, 2007 | 02:12 PM
Noyzee's Avatar
8 second mod
those are 30" tires?
you did some cutting?
Old Sep 27, 2007 | 02:47 PM
ATVracr's Avatar
Yes and Yes.
the 325/50 fit without cutting.
Old Sep 28, 2007 | 12:25 AM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
315/60/15s are 30 inches tall and 325/50/15s are 28 inches tall.
What did it run on both stages?
Old Sep 28, 2007 | 07:10 AM
ATVracr's Avatar
We will find out tonite
Hoping for a 9.2x and close to 150mph
