02 z28 Factory Injector size??
So I have heard that these factory injectors on this baby are 36#pounders.
Can anyone lend some insight into if this is true or not>.....
Found it... So they are not 36lb injectors.....
But I do have an ls6 intake....
2002 - Last year of the F-body
1. 35th Anniversary edition of the Camaro, and Collectors Edition Trans Am available
2. 2002 LS1 head gaskets redesigned. The new ones are a pressed metal, as opposed to the graphite ones and are no longer specific to the side of the car theyre installed on
3. 2002 cars continued with the LS6 intake, 28 lb fuel injectors and smaller truck cam
4. 2002 continued the use of an LS6 block in some LS1 F-bodies
5. A factory supported optional 345 HP option could be ordered from SLP
6. Manual transmission cars continued use of the Z06 clutch
7. Some 2002 model F-bodies came with a revised rear view mirror that had the map light buttons on the bottom, rather than the front.
found this information here.
http://www.lastofthebreed.com/Servic...yDiff.htm#2002
