Adding another stage...??
Old Sep 30, 2007 | 01:47 PM
2002RamAir's Avatar
Default Adding another stage...??
I have a single stage plate kit right now..getting timing tuner and maybe fjo..well im shooting a 150shot and I want another stage...how would I add another stage? I was thinking of adding a 50-100shot dry...would this be worth it? I figured all I would need is another nitrous noid and maybe a halo bar or something like that...opinions please!!!!!! Also could I rig up a activation switch for the second stage too?
Thanks all
Old Oct 1, 2007 | 05:41 PM
2002RamAir's Avatar
Anyone???
Old Oct 1, 2007 | 07:30 PM
Beer99C5's Avatar
You would need another nitrous noid, and probably a two stage window switch like the one Trick makes (sold by Nitrous Outlet and Dynotune).
Depending on which noids you had you could piggy back (like in my Sig photo) them or you may need a Y fitting and some short lines to split the mainline and go to two nitrous noids (Most vendors can make you custom length lines for that).
A bad *** Two stage control panel is a must as well
The advantage of two stage is breaking up the torque spike to reduce breakage of driveline parts, so I would recommend a two stage Window switch as a import part of your upgrade if you do two stage.
Old Oct 1, 2007 | 07:34 PM
2002RamAir's Avatar
The fjo would have the two stage feature to cover that correct?? And I have nitro daves plate kit right now...
Old Oct 1, 2007 | 07:37 PM
Beer99C5's Avatar
The FJO one would work, if your looking at the FJO controller, give Ray, Chris or Dave a call at Nitrous Outlet, they carry the FJO line.
