Opinions needed....
WHOAAA 400 shot!! I wouldnt trust my car on that big of a shot. Holy Sh****T besides the fact that if it worked my car would b sitting on the rear bumper and when i came down my oil pan wouldnt exist.After the oil pan goes the backfire that throws a rod. good luck man i would go with a GMPP but thats just my personal opinion.
throw a nice NX plate kit under it, it has tons of room front and back for the noids, then plumb a direct port on top of it.
the plate kit hits more violant then the direct port (imo) hit 200-250 out of the hole on a plate, then hit the rest with DP set up.
thats what i would do.
hope all is well tho on the personal end of things!!
i swapped gears and intake and went 9.9 but it felt so much better on the top end, no falling off ect just pulled right to 8,000 rpm.
i did the porting myself, just hoged it out a little bit. i will be doing a bit more this winter with my new tool.
the 90 mm is a restriction in my mind, the accufap and victor is cheeper then the fast intake lol
its like 450 for the one i got, looks sweet and it was easy to tune (speed dens tune)
it seems to be working well with my set up.
as for the spray, the plate kit im using seems to hit REAL HARD!!!! i love it, it hits harder then my direct port.
you will have to notch the cowl a bit, but not bad.
get a 2 step in the car to take advantage of the converter and the car will rip.
let me know if you need any help or what not, im always here to help any way i can
