Going for my first tune
Old Oct 1, 2007 | 02:00 AM
BayAreaSS's Avatar
Default Going for my first tune
So the time is finally here for me to get my car tuned for the spray. This is my first dyno tune and i want to make sure everything goes right. Can you guys give me any helpful tips or advice that i should know when i go to get a tune? I would also like to know what my AFR should be(ballpark figure). My car has bolt-ons and i'm getting tuned for a 100 shot.
Thanks
Old Oct 1, 2007 | 04:37 AM
Beer99C5's Avatar
Under 12 so say 11.5-11.8 for AFR.
If your a wet kit bring some extra jets, a couple above and a couple below the recommended on the fuel side; should you need to tune using jetting.
Make sure you have a full bottle naturally.
Instruction set for the window switch if you don't have it down yet.
Old Oct 1, 2007 | 05:45 PM
BayAreaSS's Avatar
Thanks Jim. I'm getting the bottle filled tomorrow and i'm going to double check to make sure everything is working properly before i go.
I'm really nervous about about using the spray for the first time. I have not sprayed the car at all. The first time will be on the dyno. I hope everything goes well.
