is taking fuel from the rail a good idea??
Old Oct 5, 2007 | 09:16 AM
rpmauto's Avatar
Default is taking fuel from the rail a good idea??
I have the nos plate kit and i have never had a problem, but i just read a post of a guy that had a 402, was taking fuel off the rail and leaned a cyl, hurt piston. I am building a 402 and dont really want to pull it back out on a regular basis. I have a racetronix 255l intank with the hotwire kit. would it be better, (obviously) to have a stand alone fuel system for the wet kit?? Are there other people that have had issues with this?? I will be getting a plate from niro daves for my fast 90/90. If i ever finish the build.
Old Oct 5, 2007 | 11:13 AM
BadAssFast's Avatar
I needed a stand alone at about 635 rwhp with a TH400 and a 450 rwhp NA motor using a Racetronix high current wiring.
jmill96Z's Avatar
How big of a shot are you going to run?
Old Oct 5, 2007 | 06:37 PM
rpmauto's Avatar
i will probably just run a 150 shot like i am doing now, i think that should put me into some low 10's Ya never know i might just get greedy someday and put a 250 hit on it to get into the 9's.
Old Oct 5, 2007 | 07:08 PM
BCNUL8R's Avatar
I have the nos 90mm plate kit on a 408 with a walbro intake pump pulling fuel from the rail without trouble. I'm at 632 rwhp with a 150 shot through an auto my afr was at 11.6 to 1. I would say that my fuel system is about maxed so a dedicated setup would be a good idea if you plan on going with a bigger shot in the future. I know I was ready to go with a bigger shot after only a few passes at 150, but I'm fighting off the temptation...lol
Old Oct 8, 2007 | 09:36 AM
Chris@NitroDaves
Guest
Posts: n/a
We have typically seen the racetronix systems start to have trouble at around the 650rwhp mark. If you plan on making more power than that then I would definately suggest you going to a dedicated that away you know you are 100% covered for the fueling for the nitrous. The other option would be to go wiht a new pump ( ex. Aeromotive A 1000 ), lines, and some high flow rails.
-Chris
Old Oct 8, 2007 | 10:05 AM
Zero4488's Avatar
Restricted User
I couldn't see a problem with it....especially if you upgrade your pump....
