Anyone with a big cam + 150 shot on stock bottom?
Old Oct 13, 2007 | 10:51 PM
WS6HUMMER's Avatar
Default Anyone with a big cam + 150 shot on stock bottom?
Anyone doing this? If so what kind of trap & ET's are you seeing? I guess I'm getting greedy, the 224 makes very good reliable power but I want to go a little faster. Oh yeah, will hydraulic roller lifters still work with the higher RPM bowerband? I'm specificly interested in the T-Rex cam.
Old Oct 14, 2007 | 01:06 AM
Prerun4fun13's Avatar
TTT for this i would also like to hear some times and dyno numbers..
Old Oct 14, 2007 | 01:15 AM
Thule's Avatar
i got patriot 226/226 an am goin to shoot 150
Old Oct 14, 2007 | 11:55 AM
LS1 SPEED's Avatar
not a big cam in todays world but should help you some....
SI5 231/237 .585/.595 112
https://ls1tech.com/forums/drag-racing-results/798061-dad-s-z-28-a.html
Old Oct 14, 2007 | 01:01 PM
El_Diablo's Avatar
I know a couple of guys that have sprayed a 150 shot w/TRex on stock bottom end. It scoots. Only reason I haven't done it yet is I didn't have time to install my NX kit last time I was home.
Old Oct 14, 2007 | 05:12 PM
purdueranger's Avatar
I have a G5X4 and with the Racetronix 255 pump, for some reason, my tuner didn't feel comfotable with the 150 shot on it. I have a 100 shot on it now and it hauls good. I will report back later in the week with my results at the track.
Old Oct 14, 2007 | 07:34 PM
sleeperstyle's Avatar
tnt 150 shot (gained 150 at the wheels through the th400). ms3 cam. best of 10.58 @ 129mph with a not so crazy 1.57 short time. 12 bolt/driveshaft coming soon to fix that. should et. better with a 1.50 or better 60'.
how long the bottom end will hold? i hope for a while, but who knows.
Old Oct 14, 2007 | 08:17 PM
mnypitZ's Avatar
I am running a Vinci 060, and a 125 shot. Without the nitrous I was running pretty much even with a S/C 98 Z28 that put down 406rwhp. I sprayed it last night a couple times, but no actual dyno or track times. I am running c&c d heads, pacesetter L/Ts, and the cam. I have a stock bottom end with 122k on it.
cam specs
DUR @ .004" 290*/ 294*
DUR @ .050" 228*/ 232*
LIFT .551 / .551
OVERLAP 68*
LSA 112
Old Oct 14, 2007 | 09:00 PM
WS6HUMMER's Avatar
I'm squirting a 150 shot out of the hole on a 224 right now, I wanna know about the T-Rex or the Ron Jeremy cams.
Old Oct 14, 2007 | 09:01 PM
WS6HUMMER's Avatar
What are the numbers on that cam @50?
Old Oct 14, 2007 | 09:03 PM
WS6HUMMER's Avatar
cam specs
LIFT .551 / .551
OVERLAP 68*
LSA 112
Is your car an M6 or Auto?
Old Oct 14, 2007 | 09:16 PM
mnypitZ's Avatar
M6. When I sprayed it yesterday for the first time, I couldnt keep it on the road in 2nd and 3rd went a little squirly with the Nitto DRs. Fun Fun Fun. I am guessing I am sitting at somewhere around 520+RWHP now. I just gotta watch that RPM. I was logging with HP tuners yesterday and I have a top RPM somewhere in the 7300 range. OOPS
Old Oct 14, 2007 | 09:43 PM
WS6HUMMER's Avatar
I'm kinda worried about the lift on the T-Rex or a similar cam with 600+ lift. Mine is a 563 and I know that is safe but when you go to a 600 or any cam that makes power above 6200 RPMs I know valve float could caust piston to valve contact. I'm trying to figure out if I can even use Hydraulic lifters on a cam that makes power that high.
Old Oct 15, 2007 | 02:36 AM
El_Diablo's Avatar
Here's a thread link to my local board, if you contact any of these guys they can tell you from experience.http://www.okgmp.com/forums/showthre...highlight=trex
Old Oct 15, 2007 | 08:02 AM
911ss's Avatar
i had a 232/234 cam in my ss and it loved the 150 shot.
Old Oct 15, 2007 | 10:33 AM
Black_95_Z28's Avatar
I've got a buddy that is running the TRex and spraying 250... But its in an LS1 FC Rx7, stock bottom end, just exhaust, h/c, and intake along with the n2o
Old Oct 15, 2007 | 10:49 AM
WS6HUMMER's Avatar
Wow, thats a lot of power for a stock bottom!
Old Oct 15, 2007 | 10:59 AM
alot bigger than a TR224. It's close in size with the MS4 and the TRex V2
Old Oct 15, 2007 | 11:30 AM
WS6HUMMER's Avatar
Any problems with piston to valve clearance, are you running solid or hydraulic rollers?
Old Oct 15, 2007 | 11:51 AM
silverbeast's Avatar
my buddies car has the t-rex w/ a 150 shot. He has a th-350 and a 9" w/ 4.10's. We have been a 7.12 on motor and a 6.56 @ 107 in the 1/8th and a 10.34 @ 128 in the 1/4. Race weight is around 3400 -3500 lbs. hope that helps
By Brett Foote | 2026-06-04 05:00:17
