TPS signal
Old Oct 27, 2007 | 12:39 PM
myfast70's Avatar
Default TPS signal
Not sure if this is the right forum or not but I would like to know where on the PCM I can pick up the TPS WOT wire. I am hooking up a Nitrous Outlet window switch and need to wire it to the WOT input wire on the TPS but would rather do it over by the PCM so I can keep the wire shorter and cleaner. Does anyone know which pin on what PCM connecter I need to use? THANKS!!
BTW, this is for my '01 SS
mods: if this needs to be moved to the PCM section, please do so.
Old Oct 27, 2007 | 12:44 PM
BayAreaSS's Avatar
Its pin #24 on the red connector, The wire is dark blue
Old Oct 27, 2007 | 03:03 PM
myfast70's Avatar
THANK YOU!
Old Oct 27, 2007 | 10:17 PM
BayAreaSS's Avatar
Originally Posted by myfast70
THANK YOU!
No problem
Old Oct 28, 2007 | 03:40 AM
BLOWN SS/T's Avatar
What about for a 98? thread jacking lol
Old Oct 28, 2007 | 04:19 AM
myfast70's Avatar
I finally figured out how to word my search. Here's what I found for you:
Originally Posted by Matt@HSW
On the '98:
Tach Wire:
Blue Connector on PCM, Pin 35 on PCM, White Wire
TPS Wire:
Pin 12 on PCM, Dark Blue Wire
Matt
Old Oct 29, 2007 | 12:57 AM
BLOWN SS/T's Avatar
Thanks
another off topic question that Im probaly going to have to search,lol
I have a spare 02 pcm, can this go into my 98?
Old Oct 29, 2007 | 11:23 AM
Chris@NitroDaves
Guest
Posts: n/a
IF you didn't want to go off the PCM then you could use the blue wire off the TPS Sensor itself.
-Chris
Old Oct 29, 2007 | 07:21 PM
myfast70's Avatar
-Chris
I guess you didn't read the first post in this thread
Old Oct 30, 2007 | 08:52 AM
Chris@NitroDaves
Guest
Posts: n/a
Guess not....
