2 Stage Kit
Old Oct 29, 2007 | 12:08 PM
1BaadGoat's Avatar
Post 2 Stage Kit
I was looking at doing a 2 stage Kit fired up the CNC Machine, and Got together with Barry Grant, and we made a Plate and Installed 2 Nozzles in it.
It Came Out Pretty Good. See Images. My Question is activation. I Purchased a NOS 2 Stage Mini Controller, and a FPSS. I have a 05 A4 GTO Would I need another FPSS, and a TPS Switch, and how do I go about wiring the System, as I am in no way an electrician? Any help would be greatly appreciated
Attached Thumbnails 2 Stage Kit-noskit.jpg   2 Stage Kit-noskit2.jpg   2 Stage Kit-noskit3.jpg
Old Oct 29, 2007 | 03:19 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
Looks like someone is pretty handy with a cnc machine....PM sent about a few concerns I had....the NOS 2 stage mini controller will controll both stages...let me know if you have any other questions
Old Oct 29, 2007 | 03:40 PM
TARZAN's Avatar
you *should* be able to wire them both up off one FPSS....Nice work BTW
-Will
Old Oct 29, 2007 | 03:42 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
-Will
yes the FPSS can be used to cut ground to the controller
Old Oct 29, 2007 | 04:54 PM
1BaadGoat's Avatar
Post
Thanks for the comments - Just something done down & dirty. Someone (ahem no names mentioned) expressed some concerns with the layout so I am rethinking the layout, maybe do a ring instead of a plate. Do all 4 wires need to go to the FPSS? Or just both the N20 Solenoids?
Old Oct 29, 2007 | 05:27 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
neither.....the FPSS can go on the chassis ground wire coming from the controller....it is a single wire
