msd digtal window switch question
Old Oct 29, 2007 | 07:08 PM
z-ya's Avatar
Default msd digtal window switch question
Can you pull the tach signal off the connector on the passenger side fender
with a msd digital window switch or do you need to splice into the pcm harness?
Old Oct 30, 2007 | 07:19 AM
z-ya's Avatar
I already have the shift light spliced into the pcm tach wire so I was worried about
corrupting its signal.
Old Oct 30, 2007 | 09:43 AM
Chris@NitroDaves
Guest
Posts: n/a
You can go off the coil pak plug. It will be on the side closest to the intake on the row closest to you..it should be a light green wire w/ a white tracer or a solid green wire.
Old Oct 30, 2007 | 11:10 AM
Hennytime's Avatar
you can also used the white #10 pin wire from the ecu
Old Oct 30, 2007 | 11:51 AM
Zero4488's Avatar
Restricted User
agree'd...
