ok to spray with 70k?
Old Oct 30, 2007 | 10:57 AM
chevy0128's Avatar
Default ok to spray with 70k?
i have 69k miles on my car and i am having a nitrous kit installed this friday. i didnt really think about if it was ok to do this with that many miles. so i am just hoping that isnt to high.. so is it ok to spray with 70k??????
Old Oct 30, 2007 | 11:15 AM
TINKRD's Avatar
i started spraying my car at 110k and rebuilt the motor at 135k. (nothing wrong w/ it, just had extra $ and wanted to forge it)
was making 555/576tq on 150 shot, cam only at least 3 dozen bottles
just change your oil every 3k miles. if you get really worried, run a leak down test every now and then.
maintenance is KEY!
Old Oct 30, 2007 | 11:18 AM
chevy0128's Avatar
how do you run a leak down test?
Old Oct 30, 2007 | 11:53 AM
Zero4488's Avatar
Restricted User
I got 81K and spraying....
Old Oct 30, 2007 | 12:16 PM
chrismorales75's Avatar
Stick a gauge in a spark plug hole, crank the motor, look at the gauge and it'll tell you the leak down.
Old Oct 30, 2007 | 02:19 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Depends on the motor. My buddy started spraying at 80K and it finally spun a rod bearing at 178K
Old Oct 30, 2007 | 02:45 PM
greyghost4x4's Avatar
Banging some gears
just keep your oil changed! you'll be fine
Old Oct 30, 2007 | 03:53 PM
00formLs1's Avatar
135k here
Old Oct 30, 2007 | 04:16 PM
DiabloFormula's Avatar
76k here!!!!
Old Oct 30, 2007 | 05:52 PM
TARZAN's Avatar
Should be fine, but if you're worried run a leak down like was said....I sprayed with more miles than that, with no problems
-Will
Old Oct 30, 2007 | 05:53 PM
TX RED's Avatar
140k And Still Going
Old Oct 30, 2007 | 06:09 PM
SSmoken's Avatar
just rolled over 120k.................you'll be fine.
Old Oct 30, 2007 | 07:32 PM
sobaka__79's Avatar
165k, a few 200 hits, alot of 150. just change your oil and plugs every other oil change. i dont think the n20 causes engine failure(humor me), its usually something else like your fuel delivery that causes major damage
Old Oct 30, 2007 | 08:32 PM
jmajorboner's Avatar
I did it with 60k...And did a 175 without bad things happening
