Composite or Aluminum Intake for the big shot?
But I really like aluminum, not from a performance or weight standpoint. (aluminum is about 15lbs heavier) But if you happen to get a hick-up, you can usually just drive through it with an aluminum manifold, vs. ending your day , and being out of a $1,000 plastic intake.
Robert
When I ran this set up I had the stages on 2 buttons, no window switch/ no WOT switch, and would hit hit right off the line, probably before my foot was even to the floor.
I had countless backfires with that, but it didn't matter, I wouldn't even let off... it would just drive through it.
Man that was fun.
(1) you can direct port it & if you decide to remove the kit they can be welded back up & polished out without being able to notice something was ever there.
(2) can be port/polished to increase flow
(3) not gonna break if you have a nitrous backfire
Not to mention heat soak is not a issue. The only time you'll see any effect of heak soak is in traffic while the car is sitting still. Otherwise when the car is moving & a constant supply of fresh air is entering the intake your not gonna see a difference. The air isn't inside the intake any longer than it is your heads. So if heak soak is such a problem maybe people should complain about aluminum heads also. Cause under the same theory the air has to pass by hot intake ports on the heads too before entering the combustion chamber.
To be honest, what would proabably be the best would be a single plane like the edlebrick, but machined out of a big block of delrin, or even molded and then a small machining process to insure it will sit flat, etc.etc. Then you would have the benefit of the single plane design, and no heat soaking issues at all. Why noone has made one, or tried to make one yet I do not understand.
On a normal race day if you race say in index class or whatever you probably have an hour between runs, so there is time for the icebag trick if you so choose, but a composite intake, won't need it.
Bottom line, don't try to spray big shots(anything over 150) with anything other then a DP, and you will probably be fine.
The book "Dyno-Proven GM LS1, LS2, LS6, LS7 Performance Parts"
tests all the intakes weiand, bbk, and fast etc. and the best performer of them all is the bbk ssI.
And incase of backfire this one want break
