Running Lean while Spraying?
I have a stock fuel pump with an additional 255 Walbro in-line pump on my Trans Am. I went to the dyno and recorded a 11.1/1 A/F across the board. When I hit the 125 shot (NX wet) with the proper jets I jumped to 13.5/1 across the board It acually dropped near 13.0 in the upper rpm range. I put a larger fuel jet to compensate, butthe A/F stayed the same. I had my tuner adjust the car to 12.6/1 N/A with LS1-Edit, but I am afraid that I am going to be leaner on the NOS. What to do? If I had a fuel pump problem, why would the A/F stay constant and even drop to a lower A/F at the higher rpms? Wouldn't it start getting leaner up top if the fuel delevery was the problem? BTW I have a stroked 382ci LS6 with a mild cam most of the bolt-ons.
__________________
be another upstream restriction in the fuel path.
Some solenoids look kinda small in the orifices, long
skinny fuel line might add up, etc.
