LT1 needs some spray
I have a shark nozzle inserted into a trickflow intake elbox that does the job and sprays far our from the intake track that I'm sure the nitrous/fuel is distributed quite evenly for each cylinder.
With a 150 shot, and hitting it after I got traction out of the hole, I gained approx 1.3 seconds and 17mph on my first time out, going from a low 12 second to high 10 second car. And in conjunction with my wideband O2 sensor, you can both tune and monitor the fuel to make sure you're running safely.
It may be a little overkill for what you are looking for.... but it does allow for those bigger shots of spray with a little more safety.
http://www.nitrousoutlet.com/catalog...roduct_id=2809
you will also want a way of pulling a little timing...do you already have an ignition box?
