purge smoke effect question
Old Nov 12, 2007 | 11:29 AM
chevy0128's Avatar
Default purge smoke effect question
i have a tnt f1 kit installed on my camaro this past weekend. why cant i get the cloud effect when i purge with my badass nitrous express purge kit. ITs loud and i hear it but no cloud/smoke effect. does anyone know why this is or what i can do???
Old Nov 12, 2007 | 11:36 AM
BadAssFast's Avatar
You might have air, no n20...maybe just a bad weather day for n20 clouds...humidity is a factor etc.
Old Nov 12, 2007 | 01:16 PM
FiredUpZ28's Avatar
Old Nov 12, 2007 | 02:19 PM
chevy0128's Avatar
well what is good weather for n2o clouds. i live in san antonio/houston where it is pretty humid
Old Nov 12, 2007 | 05:13 PM
chevy0128's Avatar
i want some n2o clouds.....
Old Nov 12, 2007 | 05:45 PM
billybadd's Avatar
Some seem more "foggy" than others dont they. Maybe has to do with the tubing being larger in diameter.
Old Nov 12, 2007 | 05:49 PM
donkey mule's Avatar
I drove through a nitrous cloud once - it made me laugh!
Old Nov 12, 2007 | 07:21 PM
chevy0128's Avatar
well what kind of tube should i use for the purge. right now i am using some copper wire stuff the diameter of the hole is pretty small but i hear it comin out alot. But no cloud at all completely clear and seethrough
Old Nov 12, 2007 | 08:35 PM
mrdragster1970's Avatar
6 & 8 Second Club
Sounds like air to me also.
Old Nov 12, 2007 | 09:27 PM
chevy0128's Avatar
i dont see how it would jsut be air though. Are you saying the place that sold me the nitrous sold me just oxygen instead of n2o? after they filled it up the bottle was freezing cold ...
Old Nov 12, 2007 | 09:56 PM
BadAssFast's Avatar
NXRicky has a great meterological explanation.
Old Nov 12, 2007 | 09:59 PM
MadMike329's Avatar
i'm pretty sure the cloud that you are seeing with a purge is the liquid nitrous turning into gas as soon as it hits atmospheric pressure. make sure your bottle is positioned right with the siphon tube facing down so it picks up liquid n2o
Old Nov 12, 2007 | 10:07 PM
01_ram-air's Avatar
what is your bottle pressure?
Old Nov 12, 2007 | 10:13 PM
01_ram-air's Avatar
your tube is fine. (look in the middle of my pic....same little copper tubing)
Yes, I realize I look a little scary in this pic. Apparently I didn't lean over enough for the pic and this is really the only one I have.
Old Nov 12, 2007 | 10:19 PM
waterbug1999's Avatar
AfteR I get my bottle filled, ist is actually warm.
Old Nov 12, 2007 | 10:38 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
To start with is your bottle full.? When was the last time you put the giggle juice in the tank?take your bottle out of the car and weigh it. make sure you have some mojo in there.
The white cloud you see when purging is nothing more then the water vapor in the air freezing. It is not liquid nitrous. The more humid the day to more dense the cloud will appear. Also the higher or longer the cloud will be.
now if you are hear a loud air sound then the purge noid is working, make sure there is no kinks in your purge line.
Rick
keep us posted on your results.
Old Nov 13, 2007 | 07:48 AM
BadAssFast's Avatar
Rick
And you thought I was being a wise guy.
Old Nov 13, 2007 | 12:32 PM
chevy0128's Avatar
well i put 5lbs in the 10lb tank the day after i got it installed and it wouldnt do any clouds. i live where it is really humid . Another thing is my bottle is flat the nozzle is not up from the bottom end. and my pressure is right around 1k to 1150. any other suggetions
Old Nov 13, 2007 | 03:17 PM
chevy0128's Avatar
i am hoping it is because the bottle isnt at 45 degrees. I will test it out today and let you know. THere should be some cloud effect though on all purges even if some are smaller than others is that correct
Old Nov 13, 2007 | 03:49 PM
BadAssFast's Avatar
may be your problem...siphon tube has to be in liquid at base...
