Any thoughts on a dedicated fuel system?
Thanks!
If you fuel system is at a comfortable level without the spray, then you'll be fine without it. If your fuel system is already maxed out, then thats a different story.
A standalone is never a bad idea though, you probably could run the fuel pressure in the standalone a touch higher then needed, and put 116 in there and probably leave the timing up a good bit more then what you'd normally pull for a 100 to 150 hit and not have the car lose much motor power and still be safe with the nitrous.
I don't know, mixed thoughts......
