New Gauge/Panel Setup
Old Nov 18, 2007 | 04:47 PM
Beer99C5's Avatar
Updated pics and a Vid
Right Click; "Save as" Link below (Just like a **** Site!)...
Beer's Trick Gauge Vid
Old Nov 18, 2007 | 06:22 PM
860 Performance's Avatar
I like the afr screen that records the last few seconds, that is badass for sure.
Old Nov 18, 2007 | 07:03 PM
BOTTLEFEDLS1Z's Avatar
Video is pretty badass!!! Does that gauge do the fuel pressure as well??
Old Nov 18, 2007 | 09:13 PM
SSilverSSurfer's Avatar
forgive me if i missed it, but is that a narrowband gauge or a wideband?
Old Nov 18, 2007 | 09:26 PM
Beer99C5's Avatar
It is a Wideband, I used the LC-1. The only requirement is the WB output has to be programmed to .5 V = 10 AFR and 4.5 V = 20 AFR, if your WB can be programmed for that then your in good shape.
It can do the Bottle Pressure and one other sensor. It can be a Fuel Pressure, Wideband, Boost, or "other" gauge. I have Bottle pressure and AFR. If you would rather do fuel pressure over AFR you can, I believe you can use the gauge and a fuel pressure gauge as an FPSS and enable a safety.
Old Nov 18, 2007 | 10:29 PM
cool, thanks i plan on using the AEM wideband. have you done any panels for meth kits?
Old Nov 18, 2007 | 10:37 PM
Beer99C5's Avatar
For Corvettes
Have not done any F-Bodies yet.
Old Nov 18, 2007 | 11:01 PM
i might be the first then, what gauge do they put in that spot?
Old Nov 19, 2007 | 05:26 AM
Beer99C5's Avatar
Fuel Pressure, Boost, or Wideband. Vettes can readily get a dual pillar pod, the third gauge is usually which ever one they are adding last.
Old Nov 19, 2007 | 08:47 AM
DopdBrd's Avatar
Beer, I was needing a custom gauge panel made for my 96 Formula but it has the 97-newer Center console. I am going to cut out the entire section in front of my shifter where the cubby hole was and where the traction control would be located.
Could you fab something up for me?? PM me please.
Old Nov 19, 2007 | 02:19 PM
Shuck's Avatar
That is a badass gauge, I looked on their site and didn't see it, how much does that thing cost?
Old Nov 19, 2007 | 10:10 PM
  #32
Nitro Dave's Nitrous Outlet's Avatar
Guys we have these gauges in stock!!! We will get the gauges on the site as soon as Courtnay returns from being sick.
Beer your pics and vids are awesome. You are the man!!!
Dave
Old Nov 27, 2007 | 11:04 PM
  #33
Shuck's Avatar
I looked on the site and still don't see them, am I just missing them?
Old Nov 28, 2007 | 04:33 PM
  #34
_JB_'s Avatar
That gauge is really sweet!
Old Nov 28, 2007 | 05:28 PM
  #35
supersickss's Avatar
can we get a price since there not on the page yet ??
Old Nov 28, 2007 | 06:02 PM
  #36
NXRICKY's Avatar
Closed ex-Sponsor Account
The V sells for 375.00 and the P sells for 399.00. Sensor are not included.
Old Nov 28, 2007 | 06:28 PM
  #37
GregWS6&z28's Avatar
HOLY CRAp thats beautiful
Old Feb 28, 2008 | 04:22 PM
  #38
C_Rules's Avatar
anybody know how that gauge would work if you used a nano system? would it still be able to tell you if the bottle was full?
Old Feb 28, 2008 | 04:32 PM
  #39
Beer99C5's Avatar
I am adding a NANO System, should have my new brackets Monday
The gauge will calculate for the NANO. You must program the first Nitrous bottle using the NANO through it (Tell the gauge it is full at start) and when your calling the bottle empty you select empty on the gauge. From then on, based on the jetting you have programmed into the gauge, and how long it senses the noid firing, it will read the % remaining based on your programming (When you refill the bottle you tell the gauge it has a fresh bottle...).
Keep in Mind it is not tracking the NANO Bottle, just the Nitrous Bottle.
Old Feb 28, 2008 | 09:31 PM
  #40
C_Rules's Avatar
great. thanks beer. i read your using the LC-1. mine looks like its crapping out. I get some real slow readings. doesn't even update at WOT. I should have listened to everybody and stood away from it. don't know if the lc1 is messed up or the oxygen sensor.
