n.o.s. mini controller please help!!!!!
Old Nov 20, 2007 | 01:58 PM
bowtierodder's Avatar
Default n.o.s. mini controller please help!!!!!
i have an n.o.s. mini progressive controller (with an nos plate kit) all hooked up, ive checked that its reading the correct rpm, and the correct tps signal, when i arm the system the controller dispays " r r " like is should, which means its armed but not triggered. when i floor it and its in the rpm window, the display blinks the " r r " display and it doesnt spray. i called nos tech and they suggested that i check the ground wire for the controller, so i did and its ok. other than that he said he's never heard of such a problem. anyone here have any ideas. thanks
Old Nov 21, 2007 | 07:14 AM
BLNLS1/RX7's Avatar
Is it a single or dual stage controller?
Old Nov 21, 2007 | 08:58 AM
it can be used as either, but im using it for only one stage.
Old Nov 21, 2007 | 09:21 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
how do you have it programmed.
Delay, On RPM, Off RPM, method of activation, etc.
It will either be:
Wiring....sounds like you have eliminated this one
Programming
Hardware
Old Nov 21, 2007 | 10:27 AM
i have the tps wire hooked up to the tps for activation, rpm on 3000, rpm off 6400, zero delay and start-ramp 99 and end-ramp 99.
Old Nov 21, 2007 | 11:40 AM
Zero4488's Avatar
Restricted User
if you have a FPSS...check the ground on it....or maybe it has to be adjusted...
Old Nov 21, 2007 | 01:23 PM
yeah i tried that too man, i pulled it out completly (the fpss) and it, the controller still reads the same thing.
Old Nov 21, 2007 | 05:04 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
1) Verify that the RPM the controller is seeing matches the tach...check severel different RPM's
it sounds like you have all ready done this.
2) Verify the save TPS activation voltage is below your WOT TPS voltage.
I manually set mine .2 volts below my WOT voltage.
If all of this is correct it sounds like a hardware issue, contact NOS about sending it in.
Old Nov 21, 2007 | 05:26 PM
how do i manually set the tps voltage?, i did it following the instrustions of depressing the pedal all the way, which gave me 4.3 and i saved that value.
Old Nov 21, 2007 | 05:27 PM
ShiznityZ28's Avatar
Im not familliar with the nos model. does it supply a ground or a hot to the relay?
Check and see if it is giving that maybe its wiring and not the controller. use a test light.
Old Nov 21, 2007 | 05:55 PM
DiabloFormula's Avatar
Make sure you have the correct color wires hooked up for the corresponding stage, i.e blue wire for stage 1 and red wire for stage 2, whichever color you used make sure it's programmed for the stage, make sure your trigger input wire for ch 1 matches the ch 1 wire for the noids, that's all I can think off other then good grounds...
Old Nov 21, 2007 | 06:01 PM
These units don't use a relay just a in-line fuse, they hook directly to the noids.
Old Nov 21, 2007 | 06:41 PM
So it powers the noid directly. than thats easy use a test light and see if its actually giving power. if it is then theres something in the wiring sfter the controller
Old Nov 21, 2007 | 10:18 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
as long as the controller is showing "r r" it hasn't activated...it is showing "ready" on both stages
I could manually program the TPS with the key on but motor off...slowly depress the throttle until I reached the value I wanted. I had an issue where my TPS voltage was varying at WOT between 4.6 and 4.7 .... I manually programmed 4.5.
I am running the NOS mini also.
Old Nov 21, 2007 | 11:42 PM
bigsticksupra's Avatar
make sure you set it on 4cyl mode.
the NOS mini does not power the solenoids, it provides the negative ground for them. your relay from your kit should be it's power source
Old Nov 22, 2007 | 05:51 AM
I didn't use my relay and my kit runs great........
Old Nov 22, 2007 | 07:10 AM
the proper way to wire your solenoids would be to use the relay. let me guess, your heater isn't on a relay either...
Old Nov 22, 2007 | 07:16 AM
Ya my heater is on a relay, but it never stated anything in the instructions about wiring in the relay for the mini controller and I even called NOS when I was wiring the system to make sure.
Old Nov 22, 2007 | 08:13 AM
Hey i understand r r means its on. but on doesnt mean its working right. a test light will tell you its giving its ground or positive its supposed to be. if it is then you can trouble shoot the rest of the system.
Old Nov 22, 2007 | 01:14 PM
correct
