Nitrous and timing retard - would this work?
Old Jun 22, 2003 | 12:57 PM
jimmyblue's Avatar
Moderator
Default Nitrous and timing retard - would this work?
The IAT sensor makes some spark retard when it sees
hot air. Would putting a switch inline give you
the amount of spark retard (maybe with just enough
shunt resistor to not set code when switch is open
but max the hot air retard) needed to give you
enough nitrous safety margin on spark?
Old Jun 23, 2003 | 08:38 AM
Zturd's Avatar
Default Re: Nitrous and timing retard - would this work?
I've heard of people putting in a certain ohm resistor in the IAC to make it read higher temps and decrease the timing via the computer. A switch hooked up where you can turn it on and off would be cool. I'd like to hear what ohm resistor it was i need to stick in the IAC when running the 150shot. I think with the 100shot "WET" I'm ok w/o retarding the timing.
Old Jun 23, 2003 | 10:16 AM
slow's Avatar
many people wire up a relay to do what your saying, so when they arm their system, a relay changes the IAT value, to something hot, so it pulls timing.
If you have edit, and can edit the timing tables, you can even use this to go to dedicated spraying timing table, instead of just taking a few degrees out across the board.
Ryan.
Old Jun 23, 2003 | 11:17 AM
383LQ4SS's Avatar
I had mine that way for a while...never tried it. But I found it to be inconsistant ans less than ideal. If possible...spring for LS1edit or the timing tuner from Ramchargers
Old Jun 23, 2003 | 12:37 PM
Gold Phoenix's Avatar
I haven't tried it yet and I have LS1-edit. For a 150HP shot on my system I put in an octane booster and run slightly rich to prevent knock. And to this day I have not seen it on my AutoTap.
