Nitrous 383 shortblock
Old Nov 28, 2007 | 10:04 AM
JBT's Avatar
JBT
Default Nitrous 383 shortblock
How much spray could this 383 shortblock handle?
Callies compstar crank
Callies compstar rods
Diamond nitrous dome pistons #11560
Old Nov 28, 2007 | 10:08 AM
TARZAN's Avatar
Thats a kinda open ended question in my opinion....
-Will
Old Nov 28, 2007 | 10:23 AM
siniSSter's Avatar
Forged? Nitrous setup? If you answer yes to both I'd say quite a bit if fuel is adequite. I shoot 300 with no problems except traction....
Old Nov 28, 2007 | 10:37 AM
JBT's Avatar
JBT
I suppose that the callies crank and rods are forged. Will it handle a 2 stage system with 175-200 shots?
Old Nov 28, 2007 | 10:39 AM
siniSSter's Avatar
Fuel and Timing are major factors. Play it safe and you should be fine. I wouldn't worry about a 200 shot
Old Nov 28, 2007 | 01:57 PM
TARZAN's Avatar
What kinda block? Whats the rest of the setup? Technically, those parts could handle a 400....but the rest of it might not
-Will
Old Nov 28, 2007 | 04:33 PM
JBT's Avatar
JBT
Standard LS1 block, patriot ls6 heads and edelbrock intake.
Old Nov 29, 2007 | 09:50 AM
Noyzee's Avatar
8 second mod
0-500 or more, give or take
Old Nov 29, 2007 | 10:32 AM
TARZAN's Avatar
I'd see the stock, aluminum block being the restraint with those parts....
-Will
Old Nov 29, 2007 | 04:32 PM
Noyzee's Avatar
8 second mod
i hit 400 on stock alum block
Old Nov 29, 2007 | 07:01 PM
TARZAN's Avatar
Awesome, mind me asking what you did about the heads (so as not to lift)? I'm stock cube (though it is an iron block), just curious
-Will
Old Nov 30, 2007 | 10:24 AM
Noyzee's Avatar
8 second mod
l19 head studs, fel pro MLS gaskets, thick deck heads and the right tune up.
Old Nov 30, 2007 | 11:15 AM
TARZAN's Avatar
You just made me feel much better about my recent purchase of the ETP's
Thank ya sir,
-Will
Old Dec 3, 2007 | 12:01 AM
1badA3Z's Avatar
I would make sure to have head studs on an aluminum block motor hitting it with alot of juice,just to keep it all sealed up,if u know what i mean,good luck!
