Trailblazer ss guy needs help. ASAP
Old Nov 29, 2007 | 09:53 PM
Z51C6's Avatar
Default Trailblazer ss guy needs help. ASAP
This is for a trailblazer ss with the LS2. this guy on a trailblazer ss board needs some help with a question. post up and i will forward it to him. Thanks.
"I have started to install my nx kit on my tbss and I have run into several things that have me puzzled. I am not sure which wire on the throttle body positioning sensor I need to tap into for my window switch. I have been told the purple one but I want to know for sure. Also needing to find the right line to tap into for the tach signal. I have pulled the tape on the passenger side by the coil packs and have been told its the green wire i need but again I don't know for sure. And maybe a easy 12v. accessory switch on the inside of the truck if anyone knows that also. Thanks in advance."
Old Nov 29, 2007 | 10:56 PM
Z51C6's Avatar
Anybody out there?
Old Nov 30, 2007 | 09:02 AM
NXRICKY's Avatar
Closed ex-Sponsor Account
whos window switch.
If the Trick switch
tach is green/white stripe
on the TPS you have a purple and a green on is rising one is falling. tap into either wire and check it, with your window switch. You will know right away.
I like the falling signals better.
rising works but can be a little tempermetal.
hope this helps.
Rick
Old Nov 30, 2007 | 09:06 AM
Z51C6's Avatar
Thanks, i will forward this to him.
Old Nov 30, 2007 | 09:40 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
as NXRicky said before the TPS will go on the purple or the green on the TPS sensor
here is the tach signal wire....
post #37 in the wiring sticky outlines the installation of the window switch
Old Nov 30, 2007 | 05:11 PM
Beer99C5's Avatar
He said LS2, that's a pic of my LS1 , not sure if they are the same on the wiring harness?...
I got to pretty the purge bracket up in that photo
Old Nov 30, 2007 | 07:04 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
the GTO's and C6 have had the same connector
Old Nov 30, 2007 | 07:39 PM
Blindmelon's Avatar
Blue connector off the computer pin #10 Brown wire with red tracer on the LS2 SS Trailblazer for tach or white wire under the dash going to the tach.
Old Dec 1, 2007 | 11:39 PM
kc07ss's Avatar
I still can't find a tach signal. I have tried two wires and still nothing. If the window switch doesn't find a tach signal will it not let the system work at all?
