Nitrous switch Question
Old Nov 30, 2007 | 08:35 AM
ViperJ's Avatar
Default Nitrous switch Question
I bought my car with a setup from Nitro Dave's. I am trying to program the Window switch but I have a question. What is the difference between Channel 1 and Channel 2 when programing? Is it for a dual shot system?
Old Nov 30, 2007 | 09:22 AM
Chris@NitroDaves
Guest
Posts: n/a
The channel two would be used if you wanted to put a second stage on the car.
Channel 1 = 1st stage
Channel 2 = 2nd stage
-Chris
Old Nov 30, 2007 | 09:31 AM
ViperJ's Avatar
Chris,
How do I figure out if the TPS is grounded or hot? Just follow the blue wire and see if it positive or negative?
Also since I haven't used this before does the window switch store all this once the car is turned off? It doesn't look like it connects directly to the battery?
Old Nov 30, 2007 | 10:19 AM
Chris@NitroDaves
Guest
Posts: n/a
It will store the information. If you are connecting the switch to the Blue wire on the TPS set step 7 to 002 and that will get you covered.
-Chris
Old Nov 30, 2007 | 03:09 PM
ViperJ's Avatar
-Chris
Cool, I think I am good now. Hopefully go home and spray for the first time
Old Nov 30, 2007 | 07:03 PM
ViperJ's Avatar
Just wanted to double check this since 1 blue wire is not even connected. So option 7 will be 2 and it will automatically detect WOT and spray the nitrous?
