What to spend $1500 on?
Or you could go with a clutch set up and what is left out of the money you can spend on the ls6 intake and your choice of air lid/cold air or true ram air-like the volant or scc. I would also go with an SLP MAF and a ported TB.
If you would rather run nitrous...... get a NX universal EFI kit and get every option you can! (i.e. bottle heater, opener, purge, window box, and/or anything else you want). I would also change those TR55's for TR6's AND plan on getting a fuel pump!
Josh S.
If you go with the nitrous first, plan on burning you clutch up, and if you add sticky tires, forget the rearend. Also, I would run NGK TR6 plugs if you do plan on nitrous.
I say concentrate on the basics. Suspension and tires, then start adding go fast parts. Get some QA1 shocks and springs, a BMR or Spohn Torque Arm, and a good set of drag radials. I started with the power stuff first, and only managed to burn 4 clutches, and break the rearend gears. As soon as the car layed down an impressive ET, it broke soon after.
Build a good base of: suspension, tires, rearend, and a strong clutch. Everything else is gravy after that, and your car wont spend most of its time on jackstands.
Just my .02 cents.
Just my .02 cents.
Facts are facts. QA1's have hit 1.30's on Fbodies with Hal front springs, and stock rear springs. My old Eibachs are for sale if anybody is interested to test my theory.
Semi Loose=Street Racing
Loose/Soft=Wheel pulling drag launches
They are that versatile! Easy to click dial on the side of the shocks, like a radio **** and you can go from firm to loose easy. Excellent for tuning on diffrent tracks, and changing conditions.
If your going to run naturally aspirated for awhile, I would not put in the TR6's. That is a boost/nitrous plug and may not work so great on an NA car. Stick with your original plug choice unless you go with juice.
Oh and the reason I say don't waste your time on the suspension crap right now is because I know many many cars still running their stock suspension and pulling 1.46 60 foot times... and I was one of them.
