100 shot wet! Nitrous questions,Experts inside please
Ok im thinking serious about gettin the 75-150 adjustable wet kit from dynotune .got a good deal from a friend of mine on a never used kit.
I am on stock injectors and pump .I have a 98 trans am so i belive i had the 28 plb injectors.mods are torquer v2 cam ,Full exhaust,Bbk ssi intake.
So assuming i get this kit and i will be spraying a 75-100 shot wet no more am i goin to need to pull timing or add some and IS it safe to run on My na dynotune i have for my mods already. I have a friend with just bolts on sprays a 100 shot with stock injectors and pump and tune and said he has not had no trouble with it hitting correctly and has ran it for quite awhile.
So please guys help me out i have no idea about nitrous i have never used it so i am trying to lear as much as i can .I will have also with this kit tr6s plugs,fpss and window switch
You wont need to pull timing,but like he said above,research and do ur homework before u dive into the nos world head first,but u will get a bunch more advice from alot more too,goodluck!
I'm only going to spray a 75 shot, I'm only going to spray a 100 shot, I'm only going to spray a 150 shot.... if I only had a dollar for every time someone said that. I remember saying it myself. Be prepared to start finding your weak links. Have fun and spray away. My timing is set at 25 degrees and I spray a 150. I run race gas at the track mixed with 93
well 01 ramair, you definatlly answered my question.i'm running 26 degrees timing and getting a 100 shot and my tuner told me to run a little race gas when spraying at the track.was trying to find that out. thank you very much!
98's run a good bit of timing in the stock tune (if its been tuned, you really need to know where it is). 75 shot is fine on stock timing, but for 100, I'd pull 2 degrees imo. Also, since you already have a cam, I would put a pump in it for sure... you would really be pushing it on fuel (once again imo). Racetronix with a hotwire and you are good to go for a whole bunch of future too...
