Preserving piston rings.
Old Dec 8, 2007 | 05:25 PM
pHEnomIC's Avatar
Default Preserving piston rings.
What can you do to preserve piston rings on a stock ls1? I know they are a common fail part. I am going to be spraying 150 with full safety setup. If i keep the a/f ratio right, anything else i can do?
Old Dec 8, 2007 | 08:22 PM
Robert56's Avatar
1 keep the shot reasonable
2 limit timing
3 High Octane
4 dual stage or progressive
5 start shot at a reasonable rpm
6 colder plugs
7 spot on tune
Keeping the torque in check is the biggest thing that'll help.
Robert
Old Dec 8, 2007 | 08:27 PM
Cam72aro's Avatar
Timing and good af will keep them alive for a while. Keep the shot small as Robert said. Eventually they will go away and the motor will have more blowby. Its inevitable, but you can prolong it with those things. Josh
