is a nitrous cam that much better??
Old Dec 10, 2007 | 01:16 AM
Taubr Unit's Avatar
Default is a nitrous cam that much better??
We put a nitrous cam in my buddys ls1 and it got me thinking. Are they really work that good? Lets put it this way....
car A= bolt-ons with a nitrous cam
car B= bolt-ons with a ms4 cam
Now with car B having a motor cam it SHOULD be faster then the car with a nitrous cam, just saying. Then you add lets say a 125 shot to each car. Now car B should be faster on motor so in theory it should be faster then car A. But with car A having a nitrous cam, does it make a lot better power on spray compared to the ms4? I know its kinda a weird question but its 10 deg. here in Chicago and im board, lol. Sorry.
Old Dec 10, 2007 | 11:37 PM
firefighting1101's Avatar
good question...i would like to konw the same
Old Dec 10, 2007 | 11:55 PM
RAGENZ28's Avatar
Nitrous cams are specific grinds to maximize gains "on" the bottle. Usually around 114 lobes.
Cam to cam motor only the motor grind will spank down on a nitrous grind cam.
On the bottle we went almost 0.4 faster.
On motor we had a 106 lobe, on the nitrous it was a 114.
I think the specs were 270/284 @ .050 114 lobe.
Old Dec 11, 2007 | 12:23 AM
Taubr Unit's Avatar
i dont know the exacte size of the cam but i now its on a 114+2 lsa. And i know it wasnt a huge cam by any means.
Old Dec 11, 2007 | 01:32 AM
Z-RATED94's Avatar
I believe, unless its a good size shot, and you like the way your NA cam preforms, it's not really worth it. I don't think a 125 shot qualifies for a nitrous cam swap. Just my opinion of coarse.
Old Dec 11, 2007 | 08:33 PM
Robert56's Avatar
I agree, unless NHRA bound or going real big, don't worry about dedicated nitrous cam. Use your n/a cam and if ya feel your loosing a couple hp while spraying, just put a bigger jet in, see the point.
Robert
Old Dec 11, 2007 | 10:42 PM
TARZAN's Avatar
The quickest cam only nitrous cars I've seen around here run nitrous grind cams.....It seems as though the motor cam guys on 150-175 usually run 10.8's or so, but deeper 11's on motor....and the nitrous cam guys are running 10.5's-10.6's but rather high 11's on motor...
-Will
