Safe amount of N20 for my Z06...
John
Robert
Make sure you have enough fuel and if you have custom tunning you may need to remove some timming.
Dave
Robert
Robert
Correct me if im wrong. There is no difference to the bottom end other than cam between a LS1 and LS6..
The LS based motors use Hyperutectic pistons, and the stock rods are ok but not the best.
The manufacture rating on Hyperutectic pistons are a 150 shot. This is why we call is a SAFETY point... It does not mean that you can not go past that safety point and it will not take it. It just means if you go past that point you have excedded the manufactures suggested safety point and you are taking a risk. There are alot of LS based guys spraying 200. Some have let go doing so. Some have taken the beating and kept on ticking. Just because it worked out for you does not mean that is the new safety zone and the manufactures have no idea what they are talking about.
Remember he asked What is the safety point.... Not how much can I throw at this thing and hope it lives.
Dave
As i stated before 150 is sort of the ls1 industry norm for "safe". Judging from your milage you dont seem like the kind of guy that is beating down on your car and probably take good care of it. All of which makes me want to say you can up the jets to 175-200 with the right upgrades and proper tune. "safe" really is an illusion and can vary upon vehicles. One guy can have a 150 shot blow the motor while the guy next to him runs a 250 shot for years. there are various levels of safe and there really is no defined number. start out with a 100 shot and see how you like it, then go from there.
My opinion is that the motors SHOULD take more if maintained properly and the tune up is accurate. So I agree with Robert in the opinion that they will normaly take more than the Manufactures suggested safe level.
I guess I just like to make sure the people starting out understand at what level they are exceding the manufacturer suggested ratings for safety. This keeps them having fun and not walking. As they start to gain knowledge and want to explore further they understand alittle more what to expect and that they may be taking a chance.
Dave
For those that don't know, the LS6 is much, much more than a LS1. It's the whole package that allows a Z06/LS6 to live with a 200 as a camaro/LS1 with a 150. To tell the whole story would take pages, so do the research on the mighty Z06/Ls6. I actually race the Z06 and have pushed the LS6 to it's absolute boundaries, and race with other Z06s. I maintain the National Authorized C5/Z06 Fast list over at vetteforum. I know what works and what people are running and what is successfull. So, the bottom line, if ya want to wear a skirt well then stick with a safe 150, but if ya want to man up, the Z06/LS6 platform will work wonders with a properly tuned 200 shot. If your a little worried, split the hit up into dual stage, 150 out of the hole, then add 50more in the higher RPMs or wait till 2nd gear. You could even start with a 100 shot until your used to it and move up as ya feel comfortable, then when ready for a 200shot and handing out some azz kicking from a stockish car...
Robert
for what its worth, i know the ls1 and 6 pretty well, and the ls6 is a better motor no question about it. not sure i would call it stronger do to the parts are pretty much the same, but the block itself is better, more cooling, better oiling ect ect and that may help it hang in a bit better
