ATAP and Nitrous
Old Jun 26, 2003 | 02:44 PM
FastBlackTA's Avatar
Default ATAP and Nitrous
Just got autotap and have a few questions about it.....maybe ya'll can give me a little insight...
I changed up my nitrous setup to the new NX MAF kit. To make sure that everything is working properly (basically, not running too lean or too rich) which parameters should I be looking at on the ATAP system??? I just want to be absolutely sure that everything is in proper working order before I go back to the track to make a few passes on the juice....
Thanks a bunch,
Conrad
Old Jun 27, 2003 | 08:26 AM
ls1290's Avatar
Dumb Ass Vette Moderator
Default Re: ATAP and Nitrous
Best thing is to invest the $100 for some dyno time with wideband O2 sensors to check your A/F ratio. Autotap is worthless for WOT tuning. Before you hit the dyno, you can use Autotap to make sure your LTFT are slightly negitive; -3 to -7.
Old Jun 27, 2003 | 10:22 PM
Humanoid's Avatar
All my links are at work but seach the computer forms for atap scanning. You will find config files and template to export intoexcel these will help you to determine weather or not you are running rich or lean at either WOT or part throttle.
Old Jun 30, 2003 | 08:57 AM
ls1290's Avatar
... these will help you to determine weather or not you are running rich or lean at either WOT or part throttle.
With Autotap
Old Jun 30, 2003 | 10:25 AM
Humanoid's Avatar
Yes with Autotap. Granted it is not wideband but it works.
Read away... and good luck
http://www.c5forum.com/diy/ltft.php
http://www.ls1info.com/article.php?sid=82
