nozzle placement
Old Dec 18, 2007 | 01:16 PM
b4c346's Avatar
Default nozzle placement
hi will my nozzle work o.k. here thanks.
Attached Thumbnails nozzle placement-nozzle-003.jpg   nozzle placement-nozzle-005.jpg
Old Dec 18, 2007 | 03:27 PM
3fingas's Avatar
Between the TB and MAF will work. Get a plate. You will like it better.
Old Dec 18, 2007 | 04:56 PM
b4c346's Avatar
is it sticking in the acordian enough to work correctly?it is between the mass sensor and throttle body like the instructions said. any one else please.
Old Dec 18, 2007 | 05:38 PM
3fingas's Avatar
set it as far in as you can. Then spray it and see . Obviously with out the engine running.
Old Dec 18, 2007 | 06:00 PM
b4c346's Avatar
o.k. thank you very much
Old Dec 18, 2007 | 06:31 PM
RAGENZ28's Avatar
I ran mine the same place, stuck the nozzle all the way in and let it rip, never had an issue.
Old Dec 18, 2007 | 09:32 PM
Nitro Dave's Nitrous Outlet's Avatar
As long as both Discharge holes clear the bellow you should be fine.
Dave
