running a 2 stage nx kit witch window switch
Old Dec 20, 2007 | 01:02 AM
dnkynrbk's Avatar
Default running a 2 stage nx kit witch window switch
Going to run a 2 stage NX kit that I just purchased which window switch would you recommend or how would you control it and is there a wiring diagram on here for a 2 stage thanks guys.
Old Dec 20, 2007 | 08:38 AM
DynotuneN2O's Avatar
LS1TECH Sponsor
If your window switch is has two outputs then it's easier...
http://www.dynotunenitrous.com/store...%20WET&DRY.pdf should get you close...
Cheers
Dan
Old Dec 20, 2007 | 09:10 AM
dnkynrbk's Avatar
Which window switch is best to run then. thanks
Old Dec 20, 2007 | 10:57 AM
Nitro Dave's Nitrous Outlet's Avatar
I think Dan was meaning to give you this link.
http://www.dynotunenitrous.com/store...?idproduct=194
Old Dec 22, 2007 | 06:38 PM
1BADAIR's Avatar
I use a 2 stage NX maf kit with a timing tuner controlling the first stage and a window switch on the second stage
Old Dec 23, 2007 | 08:51 PM
Robert56's Avatar
There are so many good controllers out there these days. Just check out the features for what you need/like, then pick your style. All vendors offer a few.
Robert
Old Dec 23, 2007 | 09:32 PM
Gilbert@Ace Racing's Avatar
On that TH400 you inquired about.... I could show you how to wire up the trans brake in such a manner as to allow WOT on the brake and Nitrous not spray. Not sure if you are familiar with that.... look me up if it interests you.
g
Old Jan 5, 2008 | 08:52 AM
dnkynrbk's Avatar
does someone have a wiring diagram for a 2stage nx kit with a dual window switch.
Old Jan 5, 2008 | 12:19 PM
99FRC's Avatar
If you get that 2-stage switch from Dynotune or Nitrous Outlet, it has the wiring diagram included. I just installed one in mine last week.
99 FRC
